TwinTurbo.NET: Nissan 300ZX forum - my O2s bounce at idle. they should always bounce.
Subject my O2s bounce at idle. they should always bounce.
Posted by blackomega on January 11, 2011 at 3:05 AM
  This message has been viewed 114 times.
In Reply To Your O2's aren't moving much. Is it warmed up? posted by CoHPhasor on January 08, 2011 at 12:08 AM
Message To OP: If they stick you have a bad sensor. Saturated with fuel, clogged and not ventilating, or damaged in som other way.
I tracked and tracked performance problems fo a long tme and it turned out to be O2s. How many miles are on these O2s? They are a part that goes bad over time, especially after running under bad conditions for a while. Even a short while.
If these are the same O2s that came with the car originally or if they are not OEM, replace them and then come back.
___________________
"If everybody is thinking alike, somebody isn't thinking."
~~ George S. Patton
Blow money on your Z. This is a Z forum isn't it?
